My first chucks have been Axminister SK100 then SK114. and then an O'Donnell set for the SK100. Several months ago I got a Vicmarc VM100 with the 55mm shark jaws and have never looked back. I cannot imagine a more comfortable chuck to use on a 14" lathe mostly turning bowls and smallish objects. I am going to sell both Axminsters and pick up another VM100 on sale but I cannot find the long nose jaws (to replace the O'Donnell Jaws) in stock. Are there any compatible jaws for the vicmarc chucks as there are several companies that make the long nose jaws? I found myself turning tenons and recesses even on larger items to allow me to use the shark jaws but when an object is small there is no work around. I would get the Long nose jaw - V00647 as my preference with specs showing Compression range: 7/8" - 1-3/8" and Expansion range: 1-1/4" - 3"
thanks for the help!
TD
TD
