Aluminum CBN wheel catching or digging
Kenmore, WA
I recently had a minor accident with my low speed (1750 rpm) grinder. I was using a 350 grit CBN coated aluminum wheel with my vari-grind jig. When I rolled the tool over to the left to touch up the fingernail profile, I heard a loud bang and the next thing I know my left hand was bleeding, my thumb was smashed and the jig was on the floor still holding the gouge.
When I went back to determine what happened, I found the leg angle on the vari-grind had reset from 23 degrees to zero and the gouge was no longer projecting 2 inches from the front of the jig. There was a dig in the wheel that appears to be caused by the left edge of the gouge digging into the wheel (see photo). Portions of the vari-grind that should never come in contact with the wheel also had some deep scratches.
The particular gouge I was sharpening was made of ASP 2060 steel which may be harder than most currently available gouges.
Does anybody know of a similar incident? I have never heard of anybody getting a dig in an aluminum oxide wheel. I'm interested in comments.
PXL_20240728_194516691.jpgI have more photos and details if anybody is interested. I asked the vendor who sold me the CBN wheel if they wanted it back or more information from me but have not heard back.
Sharpening is a lot like turning. What you describe would be very common while turning--having an unsupported edge contact the wood. Since you were sharpening with a jig, it would be hard to roll it far enough to have that happen and there would be no tool rest anyway.
With that in mind, it's possible that the screw/clamp that holds the tool got loose and the tool rolled to the left from where it should have been. The clamp screw gets loose all the time on our varigrind at the high school, though all that happens to me is the tool slides away from the wheel. In your situation, it might be the way you hold the handle when you grind caused the tool to roll counterclockwise when it loosened.
Or possibly the leg screw was loose and that moved all of a sudden, causing a 'collapse'.
I suggest you do a 'replay', with the grinder turned off, by setting yourself up the way you normally grind, and see if it's possible to roll the tool far enough over to catch an edge on the wheel.
I'd (with grinder unplugged) reset everything back to where you normally had it and then slowly by hand rotate the wheel while mimicking the sharpening process, and pay special attention to if any portion of anything drops at or below the horizontal center line of the wheel. if by any chance anything touched below center, then much like with a scraper on your lathe, you would have force driving the gouge down, and with the gouge trapped between wheel and V arm via the jig, several things likely had to give to make space for everything to fit until the wheel could throw gouge clear. If that is the case, might have to rethink your grinds to change angle a touch, or review your setup process. I'd imagine a CBN wheel at least didn't explode (I'd expect if the same thing happened on a frangible aluminum oxide grinding wheel, you'd count yourself lucky if it did not turn into a grenade. - I have seen grinding wheels quite literally explode on a severe catch and the person operating was extremely lucky to come away unhurt.. I got hit in the face from a piece of shrapnel and I was 15 feet away from it.)
Brian,
Thank you for sharing and for your suggestions. I have tried the replay as you suggest. Nothing gets below center line in the replay no matter what I loosen and move. I did find that the leg angle setting on my vari-grind changes sometimes when it seems fully tightened. Something is wrong with it. I know a butterfly nut is convenient but I wonder if I didn't drop the jig in a way that struck the wing of the butterfly nut which then led to a loose nut.
Here is a scenario that may explain my incident - the left edge of the gouge gets a catch which forced the gouge to spin rapidly in the direction it was going. This results in my hand hitting the grinder table and the gouge flying loose. Once it was loose, it kept spinning until the body of the vari-grind went between the support arm and the grinder wheel.
Here are the rest of my photos: https://photos.app.goo.gl/8NXsNtZvsy9kHJh56
I am replacing the vari-grind and plan to replace the butterfly nut with a hex nut. I never purposely change the angle anyway. The wheel may still be usable but I'm replacing that as well.
Joe
Thank you Dean.
One of the stranger things I noticed after the event is that the gouge protruded further in front of the varigrind after the event than before. If something hit the front of the gouge, I would have expected the gouge to get pushed deeper into the jig (i.e. protrude less). In fact, the clamp screw was so tight after the event that the knurled knob came off when I tried to unscrew the jig clamp. The gouge was so tight in the jig that I needed to knock the jig off the gouge with a mallet.
This is consistent with the entire jig spinning until it caught under the wheel. I posted a link to more photos that show the marks on the jig as well as the wheel in my reply to Brian.
Let me know if you have more questions.
I won't be comfortable sharpening until I'm sure I know what happened.
Joe
this reminds me always to wear my face shield when sharpening. I’ve been too casual.
The physician that stitched up my hand commented that I was lucky to have been wearing leather gloves at the time of the incident. And yes, I always wear my powercap mask and respirator when sharpening.
How I managed to get a 1 inch long laceration while wearing gloves still puzzles me. The gloves didn't even have a hole in them.
I do know of a similar accident that required hand surgery.
Glad you weren’t hurt seriously.
This was with a matrix wheel.
An instructor teaching in my shop was grinding a students tool that had a steep front bevel using the varigrind.
This put the gouge lower than usual and close to the center of the wheel
The gouge went to the center of the wheel, then the wheel pulled it below the center. and pulled the hand into the wheel.
Best guess is that the pocket was not locked tightly and the pocket Moved out letting the gouge move down the wheel.
The steep front bevel put the tool close to the center of the wheel so there was more downward pull from the wheel and no margin to recover from the pocket moving.
I have never had a problem using a jig in the pocket with a 60 degree or less front bevel.
I now, never sharpen an 80 degree front bevel gouge with a jig. Steep angles I do on a platform.
I would guess your situation came from tool getting pulled below center.
Something came loose or wasn’t tightened properly and this allowed the geometry to change to where the gouge was at center then got pulled below. Pocket rod moved, angle lock on the varigrind moved, protrusion lock on varigrind let the gouge move backwards.
I would guess your situation came from tool gettin pulled below center.
Thank you.
Sorry to hear about your instructor. The physician who stitched me up showed me how close I came to needing surgery. I Missed the tendon by under 1 mm.
I think you nailed it. When I talked to my mentor in the Seattle chapter about this incident, as soon as I said grinder accident he asked "any loose screws?"
I totally agree about steep angles on a platform. It seems intuitive to me.
Joe
I think your analysis about what happened is probably pretty close to right.
A couple things in the "going forward" category:
Since you never change the varigrind arm angle, and don't trust the nut to hold it... (Finger-tight doesn't do it for me - I used a pair of pliers on that wing nut and cranked it down - mine isn't coming loose on its on). ... Anyway, drill a hole between the two parts (while set at the right angle) and put in a bolt/nut. Doesn't have to be very big - a #6 would be about right. This will eliminate the dependence on the wing nut friction and keep the thing where you want it.
Watch that plastic clamp piece that sits across the flutes. One of mine has some grooves worn in it that lets the gouge sit crooked - so I have to spin it 90º to get it to clamp flat across the flutes. Worn or soft spots may also clamp less securely than it should.
But the biggest problem with the plastic clamp nut is tightening it when it's sitting on the back end of the flute (where the flats transition to the round tool bar). A couple of your photos look like it's in this trouble spot - but this may be where it jammed after the incident. In any case, when the gouge gets short, it's worth some time with an angle grinder or belt sander to create a flat for that plastic nut to sit on.
View attachment 65723I have more photos and details if anybody is interested. I asked the vendor who sold me the CBN wheel if they wanted it back or more information from me but have not heard back.
I had a similar issue with my CBN wheel. I had changed from aluminum oxide to CBN. I was using the vari-grind jig set to the proper angle and secured. When I presented the bevel of the bowl gouge to the wheel, the jig came loose and backed out of the receiver. The tip of the gouge went under the wheel causing damage similar to your picture. I was not injured but my wheel and the gouge were damaged. What I found was a build up of grit from the aluminum oxide wheel had prevented the jig from locking in place. A costly accident but no injury except to my pocket book.
There have been a number of similar incidents with sharpening spindle roughing gouges on the long arm set up with the Wolverine set up where the arm is extended a bit too far and the grinding edge gets below center. This does cause a big dig in. The pictures you show suggest a pretty big dig in. Only way I know of for that to happen is from an unsupported edge or getting below center while the cutting edge and/or tool are pointing up. Hope you are okay. Oh, for bleeding with no holes in the glove, my skin is so thin now days that if I just look at some thing wrong, my skin tears and I am bleeding, and most of the time I never know it. Also, I do have a lot of loose screws, but they are all in my head.....
Ain't that the truth. I think my skin is a little thinner than it should be at 64 but thems the breaks.
Dave, thank you for your analysis. The plastic clamp piece did not have any grooves that I noticed before the incident but it definitely has a pair now. I like your idea about the extra bolt. I will give it some thought.
Thanks for sharing, Jerry.
Robo,
Thanks. I needed a good laugh.
As a side project before this incident, I was looking into collecting statistics and case studies of woodturning related injuries. Maybe I didn't use the right search terms but I was dismayed by how little there is on the U.S. Consumer Product Safety website.
I haven't gotten around to searching these sites:
Can you think of any other publicly accessible databases I may want to check?
Joe
Folks have secured their varigrind tail/foot in a variety of ways. John Lucas, one of our really good contributors, has posted he drills a hole and uses a rivet IIRC. Dave's suggestion of a small bolt is the same concept. I seem to recall someone welding theirs in place, but I think mine is aluminum and maybe not easily welded. In any case, fixing it solidly is a good idea.
@Joe Cornell , check to make sure the axel of your grinder is the correct height above your Wolverine. If it's too high, that might cause the gouge to lie closer to the wheel's center.
Since you were working the left wing on the right wheel, you may have brought the knob on top of the Varigrind in contact with the grinder motor housing. Conceivably this could have forced the gouge to the corner of the wheel (but the scar on the wheel is in the center).
Also, take a minute to look at the Vector system/jig from Hannes Tools. The tool holder leg is already fixed. I think the Vector has a lot of advantages over the Varigrind & Wolverine system (even if you're not interested in the hatmaker's grind). The screw that holds the tool is on the bottom of the jig, so it doesn't hit the grinder motor housing--much better for doing the wings. Because that screw is on the bottom, you're clamping down on the flute side, hence no grooves such as Dave Landers mentioned, and you can secure the gouge closer to the handle as it wears down. The Vector set up device is slick and works well. It's probably more repeatable, too. The Vector fits into the Wolverine's base. The plate has 5 divots in it. The two side divots are for the hat grind. The center divot furthest from the grinder is the one to use for "regular" grinds. The two divots closer to the grinder are for taking down the gouge's heel. It occurs to me, too, that in a similar event as befell you, the leg would likely have pop out of the divot, where the Wolverine V pocket holds it firm. I don't do much spindle work, but I don't see why the Vector wouldn't work to sharpen a spindle gouge. I can't remember if I've done that or not.
I have the Kodiac Max system. Very difficult to put together & setup. Instructions okish, but difficult to set up as setting the correct vertical height of the tool holding jig pieces.
I got a similar catch on the cbn wheel, I believe occurred as tool being ground was probably just at center, or slightly below, using the jig. I really don't like the gouge grinding jig: it's very restrictive. I have been transitioning to hand sharpening, with better results. Currently entertaining going back to wolverine sharpening system. Someone mentioned the business no longer makes the zodiac max, something bout many purchasers have challengers in putting system together correctly, as I have. Not sure if Woodturners Wonders is still in business, have not received emails from them in 6 months or so. Ken Rizza was the owner back in 2023.
Never ever sharpen at or below center because that is a guaranteed "oh-shXX" disaster. I would also very strongly recommend NOT sharpening with the back of the tool handle in the pocket of the long extension arm. Always use a jig such as the Varigrind or use a platform.
+ 1 on that.
The deep back pockets on the Vari-grind and Wolverine sliding arms concerned me enough to not go with those. Likewise, the captured pivot point on Vari-grind 2. Having a deep pocket ensures the jig leg or gouge handle doesn't accidentally pop out while grinding, but it also entraps the the jig or gouge if something should go wrong.
All of the the jig systems that I have bought and made have minimal divot points on the arm. The downside of these is that the jig leg can readily pop out of the divot if you don't apply enough downward pressure on the leg to stay engaged in the recess, but the if this does happen the gouge just comes away from the wheel and at worst you may have a slight extra facet somewhere on the bevel. However, if the the arm is ever incorrectly set so the gouge tip is right on centre or near to centre with a gouge that has too steep a bevel grind (>65°) to be done with a jig, the gouge starts to dig into the wheel and be propelled backwards, which it will quicker than you can see, but the jig leg will be dislodged out of the divot and nothing more serious will have happened than perhaps an ugly extra grind on the bevel or tip.
Here a re a few examples of some arms with shallow divots...
Vicmarc at top
Woodcut at bottom
DIY
Uni-Jig
DIY
One more DIY example...
I've not used the Hannes vector jig, but it looks like it might also release the jig arm if there was dig-in. Any users like to comment on that?
Yes, I learned the hard way, happened sharpening a small diameter bowl gouge while using the kodiac gouge jig.
Have recently transitioned to using kodiac platform with better results, albeit not perfect.
I have heard of too many instances of a dig-in with aluminum oxide wheels ... and it is far more dangerous than a dig-in on a CBN-coated aluminum or steel wheel. When a dig-in happens with an aluminum oxide matrix wheel, it can shatter or throw off a big chunk of the wheel. Getting hit by a chunk of aluminum oxide (or silicon carbide or ceramic) would be bad news.
Dave: can you share a picture of the hole and inserted screw you drilled in the varigrind arm thanks
So I didn't add a screw in mine since I have been able to get the wing nut tight enough. But I do have an 1/8" hole drilled through so I can re-align it if necessary with a 1/8" drill bit to line up the holes. Described it here, with a couple pics.
From the looks of that wheel I wonder if when laying over on the right side of the tool that it was laid over too far and the top of the wing caught the wheel. Neal the Vector at least the way I use it could never get a catch on the wheel. Like I've stated before the part that has the divots is locked in and never moves. The setup jig is always the same and where the tool tip meets the wheel is well above center and I grind about a 1/32 lip for the first grind (that being the first divot followed by the 2nd and 3rd divot which are clearance cuts) When I sharpen again I am making that cutting lip smaller and when it gets under a 1/64 I then repeat the setup. It is used with a very light touch and literally takes thousands off to resharpen between setups. I get 4 or 5 resharpens before that lip gets too small. I will never wear out these gouges. In the pic below the 1st grind or primary bevel is where I start at 1/32" (the photo is from the Rockler site as it would probably take hours to find my photos of my grind). During discussions about the Vector I have been told that this is the closest a jig can get to the 40-40 grind. I wouldn't know as when I started using Thompson tools I used the setup Doug used with the Wolverine jig. Not sure if it was SWAT that Hannes brought out the new jig but I bought it as soon as I saw it and have used it since (way before the parts were powder coated).
I decided early on that this style of sharpening seemed questionable, and I'm glad to have another reminder on this point. The long V-arm is a vexing hassle to store, since my primary grinds all use the platform. Yet I keep it around as the Vari-Grind is useful for gouge profiles which are intended to be honed... I think I'm going to take a page from Eric Lofstrom and cut down the V-arm, something he does to save both space and weight in his travel teaching kit. That'll make it easier to store and use at the grinder, always a good thing.
(Tip: getting a look at how Eric has fully dialed in his travel kit is a fun bonus to taking one of his workshops!)
