Anyone using the Paasche Talon? If so, your opinion please.
Thanks
Mike
Thanks
Mike
I think airbrushes can be as big of vortex as woodturning sometimes. I don't own that model of Paasche but have an Iwata and several Badgers. She looks to be a good inexpensive dual action brush that should work well for you.
What do you want to do with it?
http://dixieart.com/Paasche_Talon_Airbrush.html
A different question, but along the airbrush line. Do any of you use the airbrush to finish your bowls? Would Deft lacquer go through them properly? Would cleanup be a pain in the .....? Would an airbrush work as good as a can of spray lacquer?
I purchased a Iwata hi-line a couple of years ago and used it for dyeing vessels. All water based and easy to clean up. Then I put it away and it has stayed there for awhile as my projects changed.
I do not want to steal the thread with this line, and if it should be a seperate thread - that is OK.
thanks.
Hugh
Hi Steve,
Thanks for the reply. I've been incorporating metal leafing as well as a few other texturing and coloring techniques into wall hangings that I do. An airbrush would lend itself to this work. For now I envision light work for the brush but one never knows where these things may lead. The Paasche Talon is in the $100 ballpark with a Iwata Hi-line around $200. I must admit that I'm wondering if I should spend the $200 now rather than the possibility of $100 now and $200 later. I learned many years ago to avoid doing that with tools (well with all purchases) and suspect that it applies here as well.
Mike
you can get a good iwata for ~100.00
i have a couple of these:
http://buynail.com/index.asp?PageAction=VIEWPROD&ProdID=628
Thats a good deal, even though I think it is an old model. I have the original version of that and it is a great brush.
