I have a relatively small shop, good dust collection and almost always wear my respirator. I currently have a small air filtration system that does up to 400 cfm. Some time this year I would like to double the size of my shop from 190 sq feet to about 390 square feet which means my current air filter will be too small. I am considering getting a second 400cfm unit but I would rather have one larger unit.
My issue is which unit to go with so I was wondering, for those that have an air filtration system, what you are using and if you're happy with it.
Right now I'm considering;
Powermatic PM1200, I like that is has a cleanable inner filter but its an expensive unit, and to add the cleanable outer filter is an additional $55.
Jet - Description also states it has an cleanable inner filter and is about $50 less than the Powermatic which would cover the cost of a reusable outer filter.
Supermax - Priced just under the Jet, comes with a reusable outer filter and I like that it has an air flow gauge on the side so you can see when its time to change/clean the filters but these never seem to be available.
Powertec and Rikon both have inexpensive units that do around 1000 cfm, are around $269 but are they just as good as the more expensive units?
I have COPD and asthma so keeping the air as clean as possible, even when wearing a respirator, is important to me. Thanks for any feedback on what you are using and your thoughts about the above units.
