A Request for Finish Advice
Phoenix, Arizona
I was wondering if anyone might have any advice for a good finish to use a newly turned baby rattle. It must be something that is food safe and durable as I am sure it will end up in the mouth or absorbing moisture from tiny hands. It might be that Salad Bowl finish or Tung Oil will be sufficient but maybe there is something else that would work better.
I have ensured that the rattle was well sanded, no sharp corners, and foid of any splinter threats.
Thanks
Ian
Williamsburg, VA
finish advise
When it comes to babies, and their ability to gnaw on things, I would suggest that the best finish might be nothing! Sand it and let life happen. The ability to wash the rattle is important, I would think, and not worrying about finishes is best. Philip, grandpa to new born twins
I look at turned rattles differently than I used to. I used to like and make the ones with rings until I had my first toddler airway obstruction in the field. Now I even question whether anything with small moveable or removeable parts should be in the hands of an infant or toddler.
Bare would be my choice, and detergent wash. Second would be something like walnut oil or even poly thinned to give some moisture resistance while not building on the surface. You can remind mom that the bare wood contains no more harm than she puts on it by scrubbing it with an unsanitary dishcloth.
Mendota IL
Ian
I use Mahoney walnut oil & his wax on my rattles.
Which style/construction are you making? I make the design found on Nick Cook's website. Its big enough to avoid choking and leaves alot of room for turning design freedom. I have 38 nieces and nephews so somebody is always making a baby and they all get a rattle from Uncle Frank. Then the kids want to buy them for thier expecting freinds.
Frank
SW Wisconsin
Nick Cook's article appeared a couple of years ago in American Woodturner. That article, "Heirlooms in the Making - Turned Baby Rattles," is one of the sample articles available for download on this site here . It's near the bottom of the page.
Phoenix, Arizona
Thanks
Thanks for the input. I do fell I need something that won't absorb the germs. But idea of mineral oil or salad bowl oil sounds the best.
Oh, some many choices!
Gaston, Oregon
Rattle
I saw no mention of the wood used....that would concern me more than germs or a bit of baby drool...let's give the mini-folks time to build immunities to disease. Some of the woods we use are toxic. Might want to be a tad careful about them and some of the glues and dyes or coloring agents. God Bless new life!!!!! :D :D
Derby, Kansas, USA
There used to be a piece on the UC Davis website about the advantages of a wooden cutting board VS a plastic one. One of the points was a distinct lower number of bacteria found during testing. The researcher felt it was something with wood.
I use a little oil to pop the grain. Beeswax would work. Film finishes would not be recommended. I read about Nick's design. I do a similar design without the split or the router work.
Turn a sphere about 1.75 inches diameter. Hollow like a Ornament, place some popcorn or Indian Corn kernels in the sphere. Turn a handle with a tenon to fit your hollowing hole. Turn a base about 1.75 inches on the end of the handle. (Makes it look like a plastic rattle design I remember my little sister having 45 years ago, like a dumbell.) The base can be a goblet style base, a sphere, an oval. The large ends make sure one can't be forced into a mouth, much less swallowed.
Include a paper with appropriate info such a species, finish, advice about sanding rough spots if the baby really gets with it.
John :)
Phoenix, AZ
What I have found is simple is best for a baby rattle. I turned a simple lidded box with a very tight fit. Put a small bead in it that I had turned. Then glued it together really well. No finish at all. The wood was mesquite, so it was very stable and took the biting & sucking with no warpage. My 2.5 yr old son still kicks it around for fun. It's nothing pretty to look at, but he really loved the sound of it when he was younger. One rule of thumb is it should be big enough not to fit inside a toilet paper tube.
Phoenix, Arizona
John :)
The rattle that I made is out of maple - pretty safe I think. I followed a tutorial I saw somewhere utilizing captive rings (a nice challenge). But I like your design and will have to give it a try.
