Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Peter Jacobson for "Red Winged Burl Bowl" being selected as Turning of the Week for April 29, 2024
It's Nordfab. Do you have a way to get the flexible hose over the ducting flange intended for that purpose?
Hot water? Some kind of shop made expanding gizmo?
Silicone?
I didn't have that problem at all. My guess is there is a metric/english conversion issue.
What id though was use silicone and hose clamps to make sure they dont move or leak
Is the flex hose also Nordfab? Do your metal connectors have raw or formed edges? I've never had a problem with raw edge connections. The diameter of the flex hose can be easily expanded a small amount by screwing it on ... twisting the hose CW a few inches back from the end while restraining the open end from turning and working It onto the flange.
If your flex hose isn't Nordfab then what Steve said is very likely. There's no problem that a bigger hammer can't solve.
