Johnathan Silwones is starting a new AAW chapter, Southern Alleghenies Woodturners, in Johnstown, PA. (click here for details)
Congratulations to Peter Jacobson for "Red Winged Burl Bowl" being selected as Turning of the Week for April 29, 2024
I'm stuck on sanding ( Plum) a 1/4" long section of an inside corner of a 3" foot, about 1/16" wide.? What's recommended. The rest of the bowl is done but this part.
It's the tiny inside corner of a foot, right? If you have a square cornered box scraper you could take very light cuts to get a clean surface and if necessary you could fold a piece of 400 or 320 grit sandpaper to a sharp corner to do a touch up. The general "rule" is to not try to sand where you have sharp inside corners. I also use a small half inch skew laid flat on the rest to use as a negative rake scraper. I carefully take feather light cuts to remove wisps of wood and that normally leaves a clean surface.
EDIT: I forgot to mention that you need to remount the piece for my recommendations. You can make a jam chuck if you don't have a vacuum chuck to hold the piece. It helps if you have a small live center.
I have several odd shaped sanding or grinding cutters for my Dremel. I will try those but they often won't reach down into the very juncture of the corner. I often just glue sand paper to a stick of the right shape to allow me to reach in those areas. I use 3M spray adhesive.
John, Thank you for your suggestion. It is a softwood so I need to be careful with the shape of the disk. I'm attempting the spray adhesion with a custom cutout. Thank you
