Help I need a drive belt for a Bonny Klein lathe
Status
Not open for further replies.
Contact Belts For Anything in Lafayette, LA. If they don't have it then nobody makes it. If there is a size marked on the belt or if you can describe it to them, they are very knowledgeable and should be able to find the right belt for you. I haven't seen what they look like, but my guess would be that they are a three rib J-section belt like the one used on the Jet mini lathe. You could also contact Bonnie Klein to see if she could point you to a supplier or tell you the type and size.
Acushnet, MA
thanks very much for the info. they are getting me the belts. Really nice helpful people to work with.
Status
