Brunton Angle Finder jig for the McNaughton Center Saver
Providence, RI
Hello all!
A few months ago, I got the McNaughton Center Saver coring jig used off of eBay. It was advertised as "used only a few times," presumably because it is difficult to set up. While searching YouTube, I came across Gavin Brunton's channel. He designed a spreadsheet to calculate and a jig to set the entry angle based on the diameter and depth of the bowl blank. I took his instructions, built the jig in CAD, and then printed it on my 3D printer.
View: https://www.youtube.com/watch?v=QViwRjm0dYc
The 3D model files can be downloaded from https://www.thingiverse.com/thing:3366592
Prints can be ordered from https://www.thingiverse.com/thing:3366592/apps/print/#apps . Note the this is a third-party service and I don't make any money off of it, and can't support any technical issues with it.
Gavin's Channel with the original videos: https://www.youtube.com/channel/UClXgFhhTjQxrOJQIT3Go61g
He has information in the comments of this video on how to get the spreadsheet he designed to calculate the angles.
View: https://youtu.be/h-KYdwELDNI
I hope you enjoy!
Well, this is a new one to me..... Have to ponder this for a bit, especially since I have always done it by eyeball..... Some possibilities here.
I see that you can buy the tool made with a 3D printer and they give three links, but I haven't found any information on the cost. I could make one the old fashioned way with a coping saw and a drill press, but that's too much like work and the end result would be pretty crude.
Providence, RI
I think you have to go through the process of selecting material and printing provider before it will give you a quote. I will see if I can figure out an easier way.
Emiliano Achaval
Maui, Hawaii
hawaiiankoaturner.com
Same here, have to admit I did a lot of funnels when I started, maybe this can cut the learning curve.
